CRAZYSHO88,
You SHO is now 8 years old. Hoses are not affected by milage, but rather the ravages of time. The anti-freeze can develope a measurable electric charge, which deteriorates the hoses from the inside.
All of the TB hoses are "pre-formed", and are available from SHO NUT, fordpartsonline.com, and fordpartsnetwork.com However, if you do not mind haveing a few hoses that are not "OEM", you can replace some of the hoses with straight hose. The one "S" shaped hose at the TB should be replaced with an OEM hose.
The heater hoses are connected to metal tubes. The tubes have short hoses that are attached with "crimpted" on clamps. These clamps can be carefully cut off so that the hose can be replaced, and a "normal" clamp used to seal the connection (stainless preferred).
I did this on a 90 SHO about a month ago. I cleaned all of the rust off of the tubes with blasting material, then primed and painted the metal with engine paint.
Mixing your anti-freeze with deionized, and ph neutral, water helps to minimize the electric charge, and acid problems. Changing the coolant every other year, at a minimum, also helps. The deionized water helps to minimize the mineral build up in the radiator, and the rest of the system as well.
As for your leak, check for the signs of anti-freeze under the hose at each connection, and at the pet-****. You should also check along the seal of the radiator tank on the drivers side. A small mirror and a light helps.
Do this every 10 to 15 minutes after you shut the car down. As anti-freeze does not evaporate quickly, a careful inspection should reveal a trace of fluid near the source of the leak. Hope this helps, rangerj
