Any help would be great
Purple Sho
Estancia (outside Albuquerque) New Mexico
Theses are all check engine lights I'm currently getting, if I clear the codes and start the car I don't get a check engine light while I'm driving... As soon as I turn the motor off and go to turn it back on the CEL Comes back on until it's cleared, I'm hoping someone on here has had the same problem, thanks in advance all
Purple Sho
Start by checking fuse 67 and/or 70 in the battery junction box
You sirs are a genius it was fuse 67, its crazy ive never seen a fuse do this but it burnt the middle section out but there was just a tiny piece holding on for dear life which is why i think once the car was running it was ok.... i popped a 20 fuse in and all my lights are gone thank you again STRIPSHO
My truck burned out a fuel pump (mini) fuse under the hood. Melted and I had to use a jumper wire to use an empty slot and a larger same amp fuse to make it right. Don't be afraid to do this if the slot is burned and compromised. You can always use an empty one with a jumper, or original wire to another slot if it will reach.
stripSHO
Idiot Savant
Detroit
You're welcome! You might want to give the wiring a good once-over to see if anything is frayed or melted or chewed up
