Venom SHO s7
about 1 month ago my 89 sho started to run at about 3/4 of the way up on the temp gauge.. and dayslater it started running pretty close to the red.. so i replaced the thermostat and it started running fine.. never more than 1/2 way up on the gauge. after that.. i happened to run across an SVT contour who wanted to race.. so i did.. after beating him 3 times i noticed the needle was up a little higher which i though was cuz of the race.. but now the car is running hot again.. i then changed the temp sending unit and its still running hot after just a few minutes of driving.. i dont see the radiator leaking and the thermostat is only weeks old.. i noticed several others SHOs that had the same problem so i thought id ask too any suggestions would help
