Frisbeeguy
This used to be a intermittent problem. At first just wriggled the wires leading to the Cam Sensor solved the problem.
Later, replaced the Cam Sensor and it seemed to solve the problem.
It's come back... violent bucking / jackrabbiting which goes away immediately upon engaging the clutch. Very hard to drive or get up to speed at all. It struggled a few miles but made it home.
Replaced the Cam sensor again yesterday - no change.
Plugged in another DIS - no change
When checking codes I got:
KOEO = 79, 19
KOER = 91, 77
After changing the Cam Sensor and driving around - it started acting up again like crazy after warming up.
No codes - crazy.
When the "episode" kicks in the tach does surge a bit up & down. It seems the radiator fan kicks on and smooths out the idle some but only momentarily.
Ackkkkk.
About 10,000 miles ago replaced Crank sensor, H2O pump, O2 sensors, new catted Y pipe, New plugs & wires (original equip - NOS)
KOEO = 79, 19
KOER = 91, 77
No codes - crazy.
Ackkkkk.
