and then there is my miss (please help)
wymjym
near Austin Texas
I’ll try to make this as short a note as possible.
I have a 97 SHO with 85K miles. I bought it from a fellow who miss led me quite a bit. I therefore do not feel as though I have any accurate history of the car.
I think the mileage is accurate. The engine did have a cam failure and it has been repaired and the cams welded. I have driven the car @ 3000 miles since adjusting the valves. There was the ‘TYPICAL’ coil miss. I performed all easy procedures to try to eliminate the problem. Then some more expensive ones, O2 sensors, maf replacement, super-duper $$$ spark plugs, etc. Still no joy, I checked the compression and the #1 bank had higher compression than #2 bank, by @ 15psi. All the cyclinders were winthin this range 165~180 (on my gage).
I swapped coils, no joy…so I finally bought 8 new coils and installed them. I checked the plugs before installing them and nothing looked obvious…some were darker and some lighter but non were white or black or really wet. Two of them were a little damp looking however. I installed the new coils, crossed my fingers and the car runs better, it idles smoother but…it still has a slight miss. I suspect that either an injector is partially clogged, the fuel system pressure is low or…I may have gotten a bad coil. The reason I think theere mught be a bad coil is that while they all came in Airteck boxes with the same part number, one of them had a different boot design and doesn’t fit very well into the spark plug valley)
The weird coil in in #4 so off comes the intake just to check that one out again.
I want to add that the wiring looks okay, not to say that there isn't a contact issue but the miss is sooooooo coil like (sometimes it idles just fine but if the AC is on it is apparent that there is a slight misfire and sometimes almost a dead miss. It always goes away as soon as the throttle it touched,
Any and all advice would be greatly appreciated as I would love to have this thing running properly.
I also ran three bottles of red line fuel system cleaner through it, new filter installed afterwards.
wj
SHO#7
Cincinnati
If the miss clears up as soon as you hit the throttle even just a little, I would suspect vaccum leak. Have you shot around the intake with some starting fluid.
Mike
wymjym
near Austin Texas
I had tried wd40 just hoping for any change in sound (no change apparant)...will try some propane tomorrow.
If I need to pull the injectors how difficult a job is that? If one of the cams is in one tooth off...how would that affect things?
wj
wymjym
near Austin Texas
okay....I went out and warmed the engine up. I opened up a can of propane..no change in idle. I disconnected the fp regulator and it changed the engine sound but I still have the miss. I guess I'll be pulling the intake etc off this weekend and study each spark plug/coil/coil co0nnection/ etc.
Any other advise (other than to cross my fingers)
wj
me6894
Canton, Ohio
did you try it around not only the intake gasket area and TB gasket area, but also the vaccuum lines?
