AMP PLACEMENT
92shoiowa
ok i got my amp hooked up and everything....but the amp ground is kinda long cause i grounded it out where you guys took me to by the latch....where is a good place to mount this and have the ground kinda short?
THANKS
RStalveyARFF
too many shos
Georgetown, MA
I hooked my amp up to the original amp rack, doing some slight modifications. Get some self tapping srews and a screw gun and you should be golden.
RickieFrat
La Cosa Nostra
State of Corruption - RI
I had my amp mounted under the rear deck. All the speaker wires were right there and you couldn't see it or the power wires.
1992 TAURUS SHO
Sig Pic By SHOTIME (THX)
MORE INFO AND PICS
1988 T-bird Turbo Coupe
Needs lil' work. Soon-to-be drag car.
AIM ... fst92sho
FRAT'S PERFORMANCE.COM
Your One Stop Source For ALL Your Audio Needs
RickieFrat
La Cosa Nostra
Originally posted by 92shoiowa:
where is a good ground around there tho?
I had a nut and bolt going through the rear deck. I sanded the metal and attached it there. I never had a feed back problem.
Now since I've relocated all the wiring i get a feed back. This spring i'll be doing a cleaning to the trunk.
undertow07
Louisville, OH/Akron , OH
I forget where I grounded, but, I mounted my amp right on my box, with the subs facing towards the rear. I removed the factory (blown) sub and put the box (and amp) up against the back seat. No wires to see! P.S. I also bought some small metal brackets at wal-mart and bolted my box to my trunk in 4 places :D , highly recommended in high theft areas!
underdog1924
Haverhill, MA
I grounded mine to a spot next to the factory amp. Have had no problems. Also a seat belt bolt is good too. It's not too long of a run.
lemkea
Grand Haven, MI, USA
my amp is in the passenger side of the trunk, all the way to the back of the car. it is mounted on a board that is screwed into the floor of the trunk, the ground is about 6 inches long and is attached to the side of the trunk under the carpet.
