I had an alternator problem last week which almost caused an engine fire. I have since addressed the problem, and I have added a modification to my charging system which, in may case has resulted in an increase in performance.
I am repeating it here again since it was moved and some of you may benefit from it.
Just an update, with a solution, to my alternator problems:
I instaled a #1 gauge wire going from the alternator output to the + post on my Optima battery. What a difference!!!
The headlights are much brighter, my stereo has more oompf, and my SHO seems to have more horse power.
I had always felt that the charging system on my SHO was lacking. I have been complaining about dim headlight for months, and now the improvement is awesome. Am am definitely going to get some brighter bulbs and polish the headlight lenses.
Voltage output at the battery is the same as before the addition of the thicker gauge wire, but I am sure that the amperage going into the battery has to be much greater.
I first noticed it when the underhood light bulb was no longer dim yellow, instead it is now shinning white for the first time. It is noticeable even during the day.
I am sure that this increase in current has given a boost to my fuel pump and ignition. I would also guess that the spray pattern in my injectors may have also improved, if the fuel pressure is higher and more consitant.
As I turn on the accessories, A/C, headlights and stereo, voltage drops from 13.80 to 12.56 at idle, but as soon as I rev the engine past 2500 rmp, it scoots back up to 13.50 Volts. I have not seen it reach 14V even with everything off or while reving the engine.
I am very happy with this simple mod. I have done this on several of my other cars in the past, but this SHO has definitely shown the greatest improvement.
Perhaps my charging system is old and tired, and bypassing it with a direct, low resistance connection fixed it.
Next I will add a negative #1 wire and ground it right to the engine.
Jose
Jose
