Aiming subwoofer
redsho
Need 4 SPEED
St. Paul, MN, USA
Hi folks,
I'm thinking about running a new subwoofer setup this summer. Has anyone tried aiming their subs differently from just firing towards the rear of the car? I will be using a single 15" (ported enclosure). I'm thinking about these setups:
1) Subs firing rearward, ports firing upward
2) Subs firing upward, ports firing upward
3) Keep same setup - Subs rearward, ports rearward
Any thoughts?
redsho
Need 4 SPEED
St. Paul, MN, USA
K-Dawg said:
With most cars, having the sub and port firing towards the rear of the car is best.
Yeah, that's why I've always been setting it up that way. Hatchbacks actually respond firing upwards. I wonder how the SHO would react with this kind of setup.... anyone have tried firing the subs upward on their SHO's?
davidb
Waldorf, Maryland
I have two 10" Kickers faceing up powered by a Sony 1000W amp. Works good. This spring I am going to change the back seat to allow the Kickers a port into the car.
[/IMG]
Dave
KILLA
SHO enough
COLORADO
The farther away the sub is from you, the louder it will sound. it gives the waves more time to amplify or something. thats why you can here someone elses bass so good, even from blocks away.
SuperHO
Mental Patient
St. Joe, MI
I've found the best position for my 12" Pioneer Premier in a ported (vented at 37hz) box is facing the rear of the car in the spare tire well. Bass response is AMAZING...the lows actually hurt a little bit. True, I lost the spare tire, but I didn't have one in the first place. Every other position I've found has been inferior to that.
dmoo21
el oh el
St. Louis Park, MN
i have a upwards firing 18. i think it sounds good, really deep but make sure that the speaker cover fabric pice is in there good or else it will shake with the air movement
its at night but you get the general direction of the sub
-Dan
SHOslyter485
Fort Collins, CO
I think it depends on personal preference. I have mine firing towards the rear bumper. I've tried the different positions, and didn't notice much of a difference. Best thing to do is try it out when you get the system
redsho
Need 4 SPEED
St. Paul, MN, USA
-Dan
18's? Wow that is big. I assume it's a sealed box, right? What sub are you using? Have you considered trying the sub using a angled/hatchback type box firing towards the back?
redsho
Need 4 SPEED
St. Paul, MN, USA
General rule of thumb - that is the best way. I've always run my subs that way. Just trying to do something different. I trying to have someone build a box for this current setup. I wondering if I should have the ports fire in a different direction than the subs, for a change.
redsho
Need 4 SPEED
St. Paul, MN, USA
How could your subs fire towards the rear, when it's mounted in the spare wheel well?
SuperHO
Mental Patient
St. Joe, MI
I said the BOX is sitting in the spare tire well, facing the rear of the car. the sub is about 4" away from the rear of the car. it's **** on the lights back there, but it sure hits hard.
rigol2000
Need a 60k
Southern Louisiana
[/IMG]
Dave
Would it be better to remove the stock sub housing? I come from the school of thought that sound sounds better to not go thru objects. Then again, I don't have experience with big bass systems.
SuperHO
Mental Patient
St. Joe, MI
Also, with two 10"s and a 1000w amp, the stock sub's not doing anything but moving with the air that the bigger subs are moving. Probably doing more harm than good.......
dmoo21
el oh el
St. Louis Park, MN
its a kicker cv-r, sealed box under spec for the sub. i had a larger box but i needed more trunk space so this is a little quieter and sealed. i have considered the angled/hatch type but then i get into space confinements again. this is a little over the top for most peoples applications.
heres another view of it
IMG 0204
SuperHO
Mental Patient
St. Joe, MI
Geezus, that thing is HUGE!!!! It's gotta make your eyes water....waaaay too much for me.
redsho
Need 4 SPEED
St. Paul, MN, USA
QUOTE]
Not bad... Not a Kicker fan myself, but heard that one is slightly better than the Comp VR's. Lots of wires sticking out everywhere :omg:
redsho
Need 4 SPEED
St. Paul, MN, USA
I'd take out that stock box too, since there's another sub playing the low notes. It wouldn't do any good to keep it. I, myself, is trying to find a stealth way to mount an 8" midbass driver inside the cabin somewhere... :oogle:
