adjustting timing belt?
buechine
Ontario, Canada
Is there an easy way if I remove the top cover of the timing belt cover to adjust the tension. It was done before I got the car and was put on too tight--I thought the tension would slack off a bit on its own but it still has that annoying whine. Any suggestions?
shojuan
sunny San Juan Bautista,
The MTX cars have a snap on access cover on the timing belt cover that gives you access to the tensioner bolt and maybe the hex adjuster hole.
Rick
The tension of the 3.2L engine is set entirely by the pressure of the gas piston tensioner and is not adjustable. I assume you are talking about a 3.0L. A new belt may whine for several thousand miles. Are you sure it is the ting belt? The Goodyear "Gatorback" accessory belts on my car let out a noticeable whine. So much that I have considered replacing them just to quiet things down.
Yes, you can reset the tension of the timing belt and no, you don't have to remove any of the timing belt covers. Place a 19mm socket on the crankshaft damper bolt and rotate the engine clockwise until the first, yellow mark on the damper aligns with the "0" degree mark on the lower timing cover. This places the engine at 60 degrees before top dead center (BTDC) on the number one cylinder and puts the greatest tension on the front side of the timing belt. For information, the second, white mark on the damper aligned to the "0" mark is TDC on the #1 cylinder.
Now remove the 2" x 1.5" door off the lower timing belt cover. Place a flathead screwdriver under the single tab and twist. This exposes the 14mm nut on the tensioner pulley. Loosen the nut about a half turn to allow the spring to reset the tension to the proper level. Tighten the tensioner nut to 25-37 lb-ft and reinstall the plastic door.
NOTE: It is very important that the engine is rotated clockwise until the yellow mark is set to the "0" index before setting the timing belt tension.
shojuan
sdpatt:
I LOVE the whine of my Gatorbacks! Sounds cool. The wife likes it too. Guess we all like different things.
I thought you were supposed to rotate the crankshaft two revolutions back to the yellow mark and then tighten the nut?
Rick
buechine
Ontario, Canada
Its a 93 3.0 mtx. Since I bought the car I have put on about 10,000 miles and the whine seems to get louder--I don't know the type of belt that he used but if it is because of a certain make of belt then I have no real problem with the noise I just thought that other pullies and belt would have some abnormal were to it. Thanks for the reponses I may try to reach the old guy that owned my car to see if he knows the make of the belt that was put on the car. If its not the gatorback I will try what you said Scott.
Thanks
Hmm, when my 89 was whining like it had a turbo, it turned out to be air in the PS system. An air purge fixed it.
shojuan:
Rick
That is exactly the process when a new belt has just been installed, but when the belt has already turned a few million times, I really don't think a couple more turns is going to make much of a difference.
