Accessory use = high temp.....????
ShoOff93
Ft Myers FL
When my ac/heat is on or my lights pretty much anything that pulls power my temp goes crazy. It went from in the red to the o in normal and all I did was shut my lights off and the heat. Any ideas? Thanks
bad connection or bad ground somewhere in the temp gauge circuit.
no, I think fixing the root cause is always better.
ShoOff93
Ft Myers FL
I took the boot off of the sensor and cleaned it and the outside of the sensor as well as tightening up the grounds and no luck. Any suggestions?
Sent from my SM-N910P using Tapatalk
ShoOff93
Ft Myers FL
I also noticed that when I have my lights on my ac doesn't blow as hard. I'm not sure if there's any correlation.
ShoOff93
Ft Myers FL
It was a ground wire that ran from the negative battery terminal to the frame by the power steering reservoir. Noticed it was a little melted and brittle and I touched it and it broke In half.
