acceptable oil pressure 3.0
93SHO24V
MN
I have a 95 sho with a 3.0l 5 speed 146k. I would like to know what acceptable oil pressure is I have an aftermarket pressure gauge that's digital and its at 60 when its cold and 30-50 warmed up
sperold
Last to Know
These motor are high volume, low pressure units. If you put a gallons per minute meter on your system, you would get some big numbers. However, oil pressure numbers are always going to seem weak.
Your numbers are too good to be true.
Most of these cars are less than 10 psi at an idle when hot (some are much less).
yamahaSHO
E85 whore
Arkansas
:) My hot idle oil pressure is about 20 PSI, but that's at 1,000 RPM idle and thicker oil.
Racer X
SHO Pilot, Retired
Connecticut
The accepted rule of thumb is 10psi per 1000RPM or thereabouts.
My engine runs at 9psi at idle when warmed up.
vortex2450
Buying Parts...
North Carolina
Under the assumption you have a unit which you have plumb an oil line to the gauge itself (versus have a sender)the reading is 60 psi at start up because there is air inside the gauge itself which rose up while the car was sitting and this throws the reading off because the oil and air compress differently. Mine will read 60 psi at start up as well but about a minute after warming up it'll jump back down.
I have a 3.2l which supposedly has a better oil pump assembly but at idle I usually have about 12 psi of pressure. Highway speeds I see between 28-40 psi. Under WOT it peaks at 60psi, maybe 65psi, I can't pay tto much attention for obvious reasons there.
Hope that helps,
-Josh
Shovert
ky
I am glad you all posted this. Saved me from a heart attack when I start mine. Thanks bunch. Maurice
93SHO24V
MN
Thanks for the input hot at idle my gauge shows 26psi so I am assuming I have good oil pressure and im running 10w30
vortex2450
Buying Parts...
North Carolina
26 psi at idle? that is still bloated, what does it read after a couple minutes of driving when your at a stop light?
-Josh
19sho90
Colorado
while we are topic, where do you guys put the "Bung" for an oil pressure gauge on the block??
NEp8ntballer
cyber ninja
fifth circle of ****
there isn't one, you have to install a T where the stock oil pressure gauge goes into the block and then you have a place to attach the stock sensor and the sensor for the gauge.
AREA 91
PA SHO SHOP
Area 91
the "T"?? Not to sure where thats at. Havent had a chance to get under my car and look for a location.
Towards the driver's side of the engine bay.
It is on the firewall side, or rear head.
Follow one of the heater hoses down to the where it meets the block.
You are very close to the sensor now.
Whydah91
Virginia
AREA91, I've been drag racing since 1961, and out of curiosity, how do you keep a drivetrain in a FWD Taurus that has to weigh 3000 pounds, hooking 336hp to the pavement, to turn essentially 13.00 in the 1/4? And you're running that through a MTX IV?
AREA 91
PA SHO SHOP
Area 91
My car weigh's 3380lbs
Yes, it's hard and expensive to do.
I run slicks, drive shaft shop stage 5 axles, and a quaife in the tranny.
With this kind of power, and slicks, something will eventually break.
Last time I snapped the input shaft in half!:evilgrin:
I really like going old school every now and then and taking my 67 Impala to the drags.
I can run as many passes as I like with no drama, or broken parts.
We also have a bracket car in the family.
FYI I also have my super comp license. :)
