acceleration problem
shocar
shocrazy
Bend
94 mtx, bone stock, the car has excessive hesitation when accelerating if its not at normal operating temperature. Bogs down severely until it gets warm up. What could this be? Does need top end done as there is oil in the plug wells.
walser
new ulm MN
try to clean out the oil in the plugs wells as best you can. brake clean and some rags. see if that helps
Oil also damages the spark plugs and they get carbon tracks in them, so they will short and misfire even after you get the oil out of there.
you will need the valve cover gaskets, plugs and wires at the least.
check for codes and see if you have other issues too.
shocar
shocrazy
Bend
Just needs the plug wires and time, I have the gaskets and I have change the plugs just recently I will let you know the outcome.
