inverse1216
ok heres the deal i did my acc. belts bout 2 weeks ago didnt drive the car much after due to a suspended license i snuck it out every once in awhile and it ran fine no problems. just the other day i get my license back so i take the car out and i smell rubber burning i get under the hood and notice that the tensioner on the second set of belts (i have a mtx) is not spinning
wtf. it would spin periodically and then stop.
so i figured maybe the belt was to loose retightened it and i also thought maybe the tensioner nut was on to tight i loosened it a hair and put it all back together and still it wont spin.
so what is the problem? do i need a new tensioner pulley? are the bearings shot? (there is no metal on metal scraping or any other noise coming from the tensioner) any help is much appreciated.
i also did a search and didnt come up with much a lot bout timing belt tensioners. the only conclusion i got from the search is that it may have seized up. thanks again.
wtf. it would spin periodically and then stop.so i figured maybe the belt was to loose retightened it and i also thought maybe the tensioner nut was on to tight i loosened it a hair and put it all back together and still it wont spin.
