ACC Reseting
Aspect
Lowell, Michigan
My Automatic Climate Control is now reseting every time I start the car when it's cold. It first started the day our temps where -12 degrees Ferenheit. It started as a very occassional problem that now has gone to every morning. It comes on fine then resets itself within 2 mintues of starting but it only does this once. Is this a sign of impending failure and how can I stop this ?
projectSHO89
SHOless In St L
It indicates that your car's electrical system is not up to par.
This is a symptom of improper battery voltage or an alternator malfunction.
Improper battery voltage at the ACC can also be caused by loose, corroded, or defective battery cables. Check those first.
It's quite possible that winter has claimed your battery, but without some diagnostic work, that is only a guess.
Steve
