ACC and LKAS
smokin5s
Ohio
Is there a way to install ACC and LKAS in a SHO that does not have that standard?
I have been told by the service department that the answer is "no"
I suppose if you could wire in the required modules and update the as-built data and/or BCM it might work. Sometimes the wiring exists, sometimes it doesn't. Certainly would be a voyage of discovery!
smokin5s
Ohio
no kidding. that voyage I think is better taken by someone with more time on their hands for sure. Especially when my transmission is now slipping if I give it too much throttle on the freeway
How many miles on your SHO? Could just need new trans fluid, or could need TSS/OSS sensors, or ...
smokin5s
Ohio
104k... last year it was BANGING when shifting at times... like we're talking thought the transmission was going to fall out... warranty covered it and replaced the valve body. Now when putting it into drive, it will rev when you first push on the gas and then catch and on the Freeway sometimes when giving it throttle it just revs and doesn't accelerate
