AC unit leaking coolant
marv
chicago
Can I remove my ac unit, it leaks coolant...or bypass it so not coolant goes through it? It leaks in front area, two down pipes, I changed radiator thinking it was that...hoses good and tight.
AREA 91
PA SHO SHOP
Area 91
The air conditioning system does not have engine coolant in it. You can remove the entire AC system, but you must retain the compressor housing, as it is used for structure in conjunction with the front motor mount.
Do you mean the oil cooler lines? These are coolant lines with antifreeze in them that are used to cool the engine oil. They are located where the oil filter is mounted.
Did I help ya or confuse ya???;)
