AC SHObra... I mean Cobra SHO...err something like that (Updated: 7/7/2012)
StreetlightSHO
It'll run eventually...
Phoenix-ish AZ
The sidepipes you have mocked up there have 4-to-1 collecters on em right? Are you cutting the collecters off or using different pipes? Just curious. :)
rbruso
unlikely
Tucson, AZ
FFR has both a true 4->1 and a fake 4->1, where it looks like a 4->1 but there's really only one pipe. I assume he's using the latter.
92sho16
b00sted
Liverpool, NY
This is correct, for the v8 you can buy headers without a collector and they merger at the sidepipe. The other setup is to use stock manifolds or shorty headers and what they call j-pipes to attach the exhaust to the side pipe. I modified the j-pipes to work with my setup. I am not sure yet of if i will be using the sidepipes as they are, the mufflers are glass packs, I have never been a fan of the sound that the SHO has when using glasspacks. I am actually hoping that the turbo quiets the motor enough to lop off the mufflers and attach some 3" pipe.
Off Road SHO
Moderator
It does quite a bit, but not enough to use on long trips. Like over a 1/4 mile or so. I lost about 4 hp on The Other Woman when I stuck a muffler on her; but I gained about 30db's of hearing back. Unless I'm at the dragstrip with her, I run the muffler.
Tom
NEp8ntballer
cyber ninja
fifth circle of ****
Tom
If only you could make a real woman 30db quieter at will...
*and not go to jail
92sho16
b00sted
Liverpool, NY
I had to mod my pickup tube. Here some pictures. I used from old tubing from a a datsun 210 EGR valve. Well had it laying around and was correct size. Don't look the greatest but doesn't leak. It was tested. Maurice
http://i177.photobucket.com/albums/w224/mgman75/93 mustang converiable/100_1286.jpg
My oil pan should be all welded up on Tuesday so I will probably be modifying the pickup next weekend. I think mostly it will just have to be shortened but thanks for the picture.
Brad kirk
