StreetlightSHO
It'll run eventually...
The sidepipes you have mocked up there have 4-to-1 collecters on em right? Are you cutting the collecters off or using different pipes? Just curious.
The sidepipes you have mocked up there have 4-to-1 collecters on em right? Are you cutting the collecters off or using different pipes? Just curious.![]()
FFR has both a true 4->1 and a fake 4->1, where it looks like a 4->1 but there's really only one pipe. I assume he's using the latter.
I am actually hoping that the turbo quiets the motor enough to lop off the mufflers and attach some 3" pipe.
If only you could make a real woman 30db quieter at will...It does quite a bit, but not enough to use on long trips. Like over a 1/4 mile or so. I lost about 4 hp on The Other Woman when I stuck a muffler on her; but I gained about 30db's of hearing back. Unless I'm at the dragstrip with her, I run the muffler.
Tom
Any updates?
I had to mod my pickup tube. Here some pictures. I used from old tubing from a a datsun 210 EGR valve. Well had it laying around and was correct size. Don't look the greatest but doesn't leak. It was tested. Maurice
http://i177.photobucket.com/albums/w224/mgman75/93 mustang converiable/100_1286.jpg
