ABS sensor
YAHTEC
Hermitage, PA
Ok, I replaced my axle shaft probably about 3 months ago when I snapped it. and during the removal I accidentally dropped a part of the axle on the sensor causing it to fray, I cant seem to find anyone that sells a new ABS or wheel speed sensor... where can I get one?
gtstang1967
BannedInBoston
New Bedford,MA
a junkyard most likely. i usually have to scrounge for parts i found a black on grey 94 atx parts car. i usually get parts from it. if you dont find one let me know ill see what i can do for you
YAHTEC
Hermitage, PA
thanks I appriciate it! another question, are the sensors SHO specific because there isn't a single SHO at any of the yards around here, tons of SLO's on the other hand.
wood_e
The dude
Ames, IA
NAPA sells ABS sensors. I got a rear sensor for about $45. Looks like the front sensors run $68.50.
Get a new sensor. I know it sucks but the yards around here didn't even bother selling me an ABS sensor. They say they're too much work to remove and many get destroyed in the process.
Oh and the sensors aren't SHO specific.
gtstang1967
BannedInBoston
New Bedford,MA
all the auto places around here dont have much for the sho and what they have isnt in stock thankfully a local junkyard has 2 92 mtx's and i found the the 94 atx near. so if you need the used abs sensor let me know
projectSHO89
SHOless In St L
The ABS system and its parts are the same for all the Taurii and Sables of the same vintage with factory ABS.
There's nothing unique about the ABS system on the SHO.
Steve
TREpaNaTion
Local Metal SHO
Minnesota
since all that other information is helpful I would like to also ask a question on this topic.. I have been having my ABS light coming on occasionally. Now when I had to replace my differential seal on the car I noticed that the abs gear? (if that is what its called) was broken and would that be the cause as to why the abs light is coming on occasionally?
projectSHO89
SHOless In St L
The "gear" is presumably the sensor exciter ring.
If the ring cracks and breaks, it will cause an ABS light when the sensor cannot pick up a proper signal from the ring.
Steve
YAHTEC
Hermitage, PA
ok, I just pulled the sensor off of my 99 parts SHO and cha ching!! it worked haha. abs system is as good as new!
