ABS problems
DJ LYX
Bronx, NY
Okay, I had my car totaly redone in 2001. I took it to an SHO mechanic here in jersey.
The work done on the car was a 120k service.
Shortly after the work was done, the ABS light came on.
At first the light would only come on infrequently. Then one day I hit a *** hole and it stayed on.
I tried not to pay attention to it but now i think its time for me to fix it.
I took a look at the reciepts from when the mechanic worked on the car back in 2001 and i noticed that he pulled several codes pertaining to the ABS. These are two digit codes that I am unfamiliar with. I'm pretty sure they relate to the ABS light being on.
CODES:
43- Right rear sensor
44- Left rear sensor
63- Motor speed sensor
67- pump relay
Also the car's CEL comes on after about 1/2 hour of driving on the high way. The engine codes are 176 and 172 (running lean). I thought perhaps that the O2 sensors needed to be changed. Do you think that the ABS may be at fault instead of the 02 sensors?
DJ LYX
Bronx, NY
::BUMP::
Sorry guys I noticed there is a another new post about ABS, thought it would be convenient to answer my Q since I have a few codes already.
justin mccluske
washington
check your abs sensers at your weels and make sure they are clean iv seen the bands on the cv axle brake and move away from the senser and throw abs lights
DJ LYX
Bronx, NY
should i clean them with the same stuff i cleaned my MAF?
thanx for the input
