ABS light problem
93MTXSHO_STUD
lubbock, TX
When I replaced my AC condenser i took out my radiator and unplugged those 3 plugs by the fan. When I had everything on i turned my car on and the abs light came on. What it does is when i get to about 15 mph the light goes on and it makes this grunt noise. Im assuming its doing something to the brake system shutting the ABS off. Is there any plugs near the radiator? Maybe I forgot to plug something? Any ideas? Oh its not battery or power related. I know when you have a low battery charge your system goes crazy and the abs light goes on. :biggrin:
Jon
EMB2580
Mike is a L O S E R
Zion, Il
Well Jon, I don't know what to tell you about the grunting noise, but it does sound like might have forgotten to plug something back in. The ABS module is right between the radiator/fan and the air cleaner housing. So, I would double check all the connections. And you are right a low battery does make the car do crazy things. What I thought to be an elsectric short causing a constant drain on my car causing it to **** 2 batteries turned out to be a loose alternator belt! Good luck!
