Well, I thought this would be one of the easy parts, but somehow it isn't. Also, I don't have pictures but I'll snap some tomorrow if it would be helpful. This is on a 90.
The ABS computer bracket has a about 12 inch rubber hose attached to a nub on the bottom. To get the computer and bracket installed I need to line up the two holes on the the car mounted bracket and the computer mounted bracket, and then the third hole that the air box screws into. Well the hard part is that dumb hose. It appears that it needs to be threaded through a hole barely larger than the OD of the hose and that hole leads to a place that is between the car and the ABS hardware. I have it almost all down there but I can not physically get the last inch or so down the hole so I can mount the computer down.
What a dumb problem! Anyway, ideas? Can I just cut the hose off, attach it to whatever it is supposed to be connected to and cap it?
