A Good Glass Adhesive?
Jake0811
Macomb MI
Having already fixed my rear 3rd brake light last week, it has come off the glass on one side. It's fallen down on one side. I stuck it back up and 10 minutes later it came off. What solid all weather adhesive could i use to stick it back up to the glass? Apparently 3M adhesive tape doesnt last long. Thank you. 2015 SHO.
SnuffyTheSeal
Florida
3M Windoweld and pray you never have to take it off. Use your 3M tape on the edges to keep it from oozing and prevent any potential for rattle
Jake0811
Macomb MI
Where could I find some? Id be way better off using that to stick it up there. The light works great! I just wanna get it re mounted so it doesn't move or fall down again.
BBLDarkStar
Southern California
If you are looking for something a little less permanent than Windoweld, 3M makes a line of tapes called VHB. It's what is used for mounting flexible solar panels on the roofs of RVs so that they don't fly off driving down the road at 70 MPH. It's pretty incredible stuff. I've bonded things that I didn't think double sided tape could possible hold and it's worked great.
Jake0811
Macomb MI
Right on! I'll try that! Thanks a million! I just want something that will hold really good and isn't a mess.
BBLDarkStar
Southern California
No problem at all. With the VHB you can at least remove the light if you need to in the future. You can cut the tape with a razor blade at a corner then slowly start working your way through it to from one side to the other to remove it. If it doesn't work for some reason you are only out the cost of the tape and there won't be any damage. Good luck!
hosbaldosho
