'99 SHO - hesitation/stall on acceleration
jimk
MO
Just got car running after sitting for long time. Idles fine. Gentle, slight press on the gas pedal makes the car move but then it stalls for 2-3 seconds, RPMS drop to below idle, then RPMS return to normal. Runs Ok at highway speed, holds 60 mph but not sure if it hesitates when accelerating.
Is there a fuel pressure regulator? I need to find a better adapter for my fuel pressure gauge as i can't seem to get a tight connection at the manifold port.
gmail
Well-Known Member
sunbury pa
on a 02 taurus i had this problem and the maf was dirty. easy fix. maf cleaner and about 30 seconds it ran .
only difference was at highway speeds and WOT it would kick and butt
jimk
MO
And just how would the MAF make the fuel pressure drop to 5 psi ?
