SHOBen
For the 96 brake upgrade do you have to use spindles and brakes off a SHO or does a sable or standard taurus have the right parts?
If you have 94'-95' sho you can use existing spindle otherwise steal spindle from any 94'-95' slo or sho's!SHOBen said:For the 96 brake upgrade do you have to use spindles and brakes off a SHO or does a sable or standard taurus have the right parts?
shopartsnw said:I am a little biased (pardon the pun) because we build the SHO lettered Stage 3 kits in 12" and 13".
We have run the 96 kit in the past, and it is a great street setup. Many of us tracked (road course) on the 96 kit, and thought it was the greatest thing since sliced bread. That was until we ran a set of 12" or 13" Cobra PBRs.
The 13" Cobra PBR kit is a great value for the stopping power. Make sure everything is strapped down in your car because it will end up on the dashboard (or in the back of your head). You need 17" wheels (or the perfect 16" Team Dynamics rims) to run 13" brakes. so there can be an extra cost in wheels if you don't have them.
The 12" Cobra PBR kit costs more than the 13" kit, but it fits under slicers and most 16" wheels. The braking force of the 12" kit is only slightly less than the 13" kit, and it is lighter, so I think you pick up a little acceleration as a trade off.
96 rotors can warp, but I have yet to warp the 12" or 13" rotors. You also get a huge selection of pads with the Cobras you don't get with the '96 kit.
I have never ran the Stage 2 kit (Mustang GT over 10.2 rotors), but the smaller rotor worries me a bit.
Some people are running a Cobra caliper over an 11.6 rotor, which I think is better, but I am a little worried about warping the rotors under harder use.
I don't know if that helps. Personally, I am sold on the 12" or 13" kit. Everyone who has tried them would NEVER go back to the 96 kit, but if you only need a street set up, the 96 kit works great.
- Mike
quikSHOilver said:If you have 94'-95' sho you can use existing spindle otherwise steal spindle from any 94'-95' slo or sho's!
Yea Yea thanks for amend!NWGRN94MTX said:As long as it has the ABS provision.![]()
PAracer said:Another question on the same subject...
Is there anything I can do with my current Mustang GT setup to upgrade further? I am trying to explore my options as far as finding a new setup for the upcoming track season. The GT brakes are not enough, and the calipers flex/spread after a while.
ford_freak said:Which one would be good for daily driving and the weekend autocross? Any exprience would be appreciated
I have a 90 model, so basically any spindle will work or any taurus 1994-2000?quikSHOilver said:If you have 94'-95' sho you can use existing spindle otherwise steal spindle from any 94'-95' slo or sho's!
Fixed it for ya.PAracer said:One thing to note is that the GT calipers are sold separate from their brackets, depending on where you buy them. The heavy duty Cobra calipers are sold with brackets and slide pins.
Racer X said:Fixed it for ya.
When I had to replace my GT calipers after the "overheat" incident, the replacements I bought came with new brackets and slide pins. Some places sell calipers with brackets, some don't. Depends on the place you shop at.
I went off of what Rock Auto was showing me.
