95 Sho radio
90sho
New Jersey
I just hooked up a after market radio to my 95 sho and everything works just that when u put up the volume thier is static from the speakers. I dont think that it can be from the wiring, and i disconnected the sub in the rear because i thought it drained the power. SO does anyone know how to get ridd of the static. Thank you :oogle:
SuperHO
Mental Patient
St. Joe, MI
Yeah...get an amp bypass for the silver amp in the trunk. I can almost guarantee that's where it's coming from.
oh_SHO
Ohio
Yes! Because at this point the stock amps are amping your signal from the headunit. I ran it like that for a while but my headunit had a feature when it dropped the wattage to accomodate the stock amps. There is also a set of plugs (already stock) that bypass the amps completely. I used those when I redid my stereo...
90sho
New Jersey
Where are those plugs, and can i just unplug the silver amp idont want to use the stock amps anyway.
masho95
got Zex?
Chicopee, MA
I've had the same issues with an aftermarket HU. Installed the amp by-pass in the trunk, same issues.
It's not a Clarion HU by any chance is it?
90sho
New Jersey
No its a JVC i did the bypass its still staticy. But only when i play a cd, when i put the radio on its clear what can cause this to happen
SuperHO
Mental Patient
St. Joe, MI
well, let's see...what can cause static from an aftermarket CD playeR? two things we've covered; lack of amp bypass and dirty CD laser. Other things are bad ground, crappy CD player, crappy stock speakers, bass/treble turned up waaaay too high for crappy stock speakers and distortion being mistaken for static......
that's about all I can think of off the top of my head.
