95 atx starter wires
95mtxsholove
Staten Island, NY
how many wiresshould be hooked up there is a little wire net to my starter not hooked up i think its yellow wit a little red stripe does anyone know where it goes?:omgsho:
TYSHO
Earth
There should be two on the starter, your power and ignition wire (very small). The ground is hooked up on the mounting bolt/stud, on the transmission side.
animex2
T9 Technician
Buffalo
call me a gravedigger but im having trouble wiring my starter back up.
I got the ground on the transmission side.
and i got 3 power wires on the other side. 2 thicker wires (4 gauge?) one going to the fusebox with the small 12ish gauge wire on it, and one comming from the battery. I think I have the 2 big wires on one of the leads, and the smaller one on the other lead, but I cant get the starter to turn.
TYSHO
Earth
You want those two thicker wires on the same post. They need to go on the post further from the starter, if I recall correctly. The other post has a silver braided wire going to the starter from the solenoid, that post does not receive the two loose wires. The solenoid jumps those two post with the small ignition wire you can only hook up to one spot. If you have the power wire from the battery hooked on the wrong post, the starter would be cranking as soon as you hook the battery cable up to the battery. If you have the power wire from the battery hooked up to the correct post and the accessory power wire on the other post, I have no idea what would be happening but I know you would be missing some power to quite a bit of power consuming sources in your vehicle when the key is let off from an attempted start. If your radio, head lights, fuel pump, and ect come on when you turn the key to the run position, you have it hooked up right and are experiencing a starting problem and would need to list your symptoms and when they became present.
