gurucomputers
Ok to start with I have replaced the thermostat, ETC Sensor, Water pump, and Radiator cap. I have a new radiator from a buddy that I am going to put in soon but here is the problem: I took the rad cap off and stuck a water thermometer about 10 inches down inside the rad. I started the car and let it idel for about 5 min. The inlet and outlet heater hose were the same temp to the feel. At about 10-15 min the water temp started to rise on the thermometer. The temp finally rose to 250 F and the fans did not come on. I looked at the guage on the in the instrument cluster and it was at the R on NORMAL. I know the factory guage is not accurate so I ignored it. I turned the A/C on and the Rad cooling fans kicked on. I watched the thermometer as it went down and the fans kicked off at about 200 F. Then the temp started to rise again with the A/C off. The temp got up to 250 and the fans did not kick on and water started boiling over. I turned the A/C back on again and the fans came on and the water stoped boiling over immediately. The temp went back down to about 200 F and the fans kicked off. What is the deal I am at a total loss for the problem.
Got brass one from Autozone and good to go fans work like new now. Thanks for all the help.
