I'm new to SHO's so I may be a lil bit confused.
My car drives fine except when you floor it. The RPM's climb to around 7,000 before it seems to shift and go on.
What I wanna know is the tranny slipping or is this normal.
Also, The check engine light is on and has been since I bought the car. i ran codes and came up EGR voltage too low so I swapped the EGR valve. Light is still on but it comes and goes.
When I ran codes it came up also CID sensor, BOO switch or "Brake on/off switch", and PS/PS sensor.
I swapped the PS pump hopeing the PS/PS one would go away since I was getting a whinning noise from what I thaught was the pump. Turns out the whine was a Idler pully.
I think the BOO switch maybe why the cruise control was un-hooked.
Sorry to throw so much at once but like I said I'm new to these cars and just purchased this one for $1,000 with 117,000 miles on it.
Only thing is it's a '93 w/ 131,00 mi. on her. So how much is it 2 reprogram one of those babies.
