rpb51
I have a 93 ATX that I've gone through for the last 4 years when I've had time.
The car only has 60K (verified) so I did a 60k tuneup, timing belt replaced with all marks lining up at TDC #1, water pump, VC gaskets, valve adjust, CPS, intake fully dismantled and cleaned, new plugs, 8mm Taylor silicone wires, cat back exhaust, fuel filter, etc. Got it back together with all the hoses hooked up right and all the ground wires triple checked and resistance tested. I've got good spark and fuel in the rails with good pressure. Still won't start. Cranks strong but no hint of turning over. I pulled a plug and don't think I'm getting fuel in the cylinders. Could the injectors be stuck shut? I replaced the gas tank and fuel pump and it's all working fine. I also pulled 111 codes so I'm at a lose for what to try next. Any ideas?
