93 ATX Stalling
SHOsFAST
Who's Running?
Colonial Heights, Va.
when I floor it from a stop my car stalls, the Idle is okay and it performs okay as long as I don't suprise it from a stand still. Also My fuel pump is pretty loud as well if thats info thats needed. It will do it in reverse also, after it stalls I can start it right back up... any help would be greatly appreciated!
Thank you,
Graham
naval-avi8or
Chesapeake, VA
Does it do it in nuetral or only in a loaded (fwd or rev) condition. Have you checked the fuel pressure at the fuel rail @ idle and under a load. How old is the fuel filter.
SHOsFAST
Who's Running?
Only under load, have not checked presure and I have no idea how old the filter is I have had the car for three weeks or so, but I'll check the pressure and replace the filter ASAP.anything else ar does this look like a fuel delivery issue.
projectSHO89
SHOless In St L
Since the problem manifests itself at tip-in, I'd suggest a quick check for the MAF (engine off, disconnect it, start engine, and see if the symptome goes away - ignore this CEL) and the TPS (check with a meter for smooth, linear operation).
Fuel pressure test is also a good test.
Steve
SHOsFAST
Who's Running?
Thank you for the ideas, I'll start her up w\out the maf when I get home tonight, ProjectSHO do mean a volt meter on the TPS?
