seraphiem
Car has been running decent for the past 500 miles or so since I did both the upper and front 60k.
Today, the car refuses to start. When the car cranks over it sounds ridicously bad. Sounds like very uneven firing, wish I can even begin to describe what it sounds like, but it sounds very bad.
NOTE: This is the first time this has ever happened. I never had any warning signs until this occurance today.
Being rather illogical I first suspected the timing as I remember the new belt had a new more slack then I would like when I installed it. I figured the belt jumped as the way the engine shuttered seemed like it was fighting with itself. Yet upon pulling the upper timing cover, I discover both the cam shafts are in time. No clue how the crankshaft itself lines up as I haven't pulled apart the rest of the front yet.
I believe I do not have spark. No arc. I do have fuel, no clue on actual pressure, but figured the car would at least kick over with low fuel pressure.
The CPS is about 500 miles old, the CID is the stock one with 147k on it. Unplugging the CID and extended cranking sessions does no good.
To aid in the uneven cranking and sounds is the tach. The tach fluctates from 500 to 3k when cranking. Again, the engine sometimes sounds as if it is spining waay too fast and then slows down to a more normal cranking speed. I figured the CPS must be working since the tach does work.
I found rangerj's excellent directions to diagnosing a no-spark condition. All components good from his procedures. Checked the under-hood 10A Fuse, good and even dropped in a spare I had.
My questions,
#1 Does this very strange fast and then slow cranking sound familiar to anyone? Again may tach goes upto 3k when cranking over.
#2 Would the no spark condition cause this irregular cranking?
Thanks In Advance
My questions,
Thanks In Advance
