93 ATX High pitch whine from engine bay
TicoSHO
93 in Largo, FL
Largo,FL,USA
I have a 93 ATX and just had the alternator rebuilt. I have noticed a high pitch whine from the engine bay. I don't think it is the power steering because it doesn't change in pitch when I turn the wheel. It changes in tune with the engine revs. It sounds like it coming from the passenger side of the engine. Could this be the alternator? Thanks guys.
ohioshodude
SHO'ld fogy
delaware, ohio
it could possibly be the intake tube. crazy i know but when it does it, grab the tube and pinch it. it has some weird harmonic while at idle that makes it hum.. if not that i have no clue. :thumb:
TicoSHO
93 in Largo, FL
Largo,FL,USA
No, no blower.
I wish. But I don't think the tranny would handle the extra power.
TicoSHO
93 in Largo, FL
Largo,FL,USA
It's coming from the passenger's side not driver's side. The pitch will go up as the revs go up.
Cwynn
Batavia, IL
My guess is that one of your accessory pulleys or acessories is making the whine. Try listening to them with a mechanics stehascope or a long metal rod/screwdriver to pinpoint where it's coming from.
Huntervf
Bored now
Back in Michigan ... again.
Could be your freshly rebuilt alternator wasn't rebuilt properly. I had the exact same problem with a reman unit I put on my SHO. 20 miles later the thing would make this outrageous whining noise if the revs got much over 3k. The reman alternator was coming apart... I could grab the pulley and move it 1/8 inch in/out.
TicoSHO
93 in Largo, FL
Largo,FL,USA
Spoke to the Mech today. told me that the Alt was rebuilt wrong, but that was not my issue. He told me it was the idler pulley. Told me it would be $103 from ford. Is that a reasonable price? :shrug:
rlw001
Reading, PA, USA
No. You can use the Gen III pulley or replace the bearing in the one you have. I think I paid $15 for my Gen III pulley and it works fine.
TicoSHO
93 in Largo, FL
Largo,FL,USA
Too late, Mech already ordered the pully. If the forum hadn't have been down yesterday I'd have had him get one from a gen III . Oh well, now I know. The noise was getting pretty loud. What could have happened had I let it go? I ask in case anyone is just dealing with the noise rather than the fix.
AREA 91
PA SHO SHOP
Area 91
Eventually the pulley could freeze, abd burn up the belt. Option 2 is that the pulley starts to wobble so bad, it throw's the belt off. In either case, it's bad. Don't feel too bad, my Mocha has the same problem right now. :nut:
SHOdownTN
Texas
I replaced mine, it was the idler whineing. Sounded cool though. zzzzzzzzzzZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ!!!!!!!!!!!!!!!!!!
People thought I had a supercharger.......
FO-SHO
Philadelphia
I think I am experiencing the exact same problem. Engine sounds a little different, is running a little hotter and louder. I have been through a couple different ALT's with no change. Are you having any electrical issues? Let me know if changer this fixes the prob, thanks.
