lntanth
I have a 92 sho that I got from a buddy he got it from a auction it wasnt running when he got it He thought it was the fuel pump and replaced it still didnt run then he thought it was the timing belt he replaced it and it still wouldnt start and he gave up and sold it to me for 250 dollars. To me it sounded like it was a timing problem so I redid the timing just to make sure but still wont start so I replaced the CKP and the CMP still wouldnt start checked spark plugs alot of oil in the wells so I replaced the valve seals put new spark plugs and wires on it still no start pulled codes and get 111 for memery code and 111 for the hard code I also noticed from reading this fourm that the spark plug wiring order is differnt then what is in the chilton book what is the correct order? When I have them hooked up like the chilton book the engine just turns over like it wants to start just wont When I change them around like I read on this fourm I get back fire out of the intake manifold and still wont start. If any body has any sugestions on what might be the problem I sure would appreciate it. To help you I now that I have spark,compression,fuel.
