After picking up the MTX headers from rbruso (Thanks), managed to get them hooked up to see how things would fit. Unfortunately I have interference between my cradle bracket (for mounting the engine to the test stand) and the ****** on the front header.
There's also no room now for the 1.5in X 2in vertical support which is supposed to sit behind the bracket.
This shows the engine bar support and a tube for the bar taped to it. There is just enough clearance between the engine bar and the Y-pipe - about 0.2. I have the same 0.2 clearance between the top of the engine bar and the oil pan.
The back side is more forgiving since the Y-pipe is not as close to the oil pan on that side.
I don't think I can change my cradle support sufficiently to make it work with the MTX headers & Y-pipe. The ATX header ****** sits much higher, and the pipe angle allows more room.
It looks like I'll have to use the Y-pipe pieces I have to fabricate one just for the bench test. That way I can get the fit closer to what I need. This would also be good practice for the final exhaust as well since it looks like I'll have to fab the Y-pipe as well.
I noticed that the portion of the Y-pipe that crosses under the oil pan keeps a good distance. Instead of crossing under my engine bar, I'd like to cross between it and the oil pan. Can I fab my crossover to be closer to the oil pan if I plan to wrap it with some insulating material?
Another thought would be to cut up one of the header heat shields to fit between the crossover pipe and the oil pan and mount it to my engine bar.
