OK did another fit today and added the surge tank. It definitely changes a few things. You can see that the surge tank wanted to hit the front firewall, so I needed to lower the motor and move it back 1/2 inch. This give me good height and clearance for the tank.
That means though that I don't have enough height for the biscuit mounts - they end up being too tall. That gives me plenty of clearance between the engine bar and the oil pan.
When I add the motor mounts on both sides - they do line up in the correct longitudinal position in relation to the engine bar, but when attached to the bar, they will close some of the large gap between the bar and the oil pan (to approx 3/8 in).
Left motor mount
Right motor mount
So overall the height and the length are proving to fit well. I only need to adjust the height between the engine bar and receiver plate. I figure I can do this with a thick high-density rubber washer.
With this longitudinal position of the motor, I get good tranny drive shaft alignment to within 1/4 inch back of centered.
I also get the large gap I was expecting at the rear tranny mounts. So I will have to come up with either a custom mount, or a custom adapter plate to mount the stock pieces.
I'm starting to get stoked now that it looks like it will really fit as planned. I'm hoping to get the mounting arrangement completed before the end of the year.
