fredhurderjr
I’m having BIG problems getting the 91 fired. We have changed the plugs, crank sensor, cam sensor, DIS. Timing is all lined up (& was already). We have fuel pressure (about 40psi while cranking), we have spark. Compression test = ~190psi front bank of cylinders. We have not changed the coil pack, the wires are (front – back, left to right) 465-321, the computer is a remanufactured 91 (L0S code). The car stumbles, stumbles best with no pressure on the gas pedal, after sitting for days. The oil sending line (near the drain plug?) has a significant leak. Other than that, I see nothing out of the ordinary. SHO Shop Y-Pipe & Cat-back, looks like new O2 sensors. It has a fresh “remanufactured” computer.
Previous owner had a 75 (77?) mm MAF with an LPM (2 actually), before he took it to the shop he put it back to the 55mm. He said he got it back from the “garage”, it drove 2-4 miles, & got to the point it is now.
Thanks for the feedback & suggestions ahead of time...
White 95 SHO MTX
"Jezebel"
Spends more time in the shop than in the driveway
Teases me with occasional great runs
3.2L SHO Shop Long Block
9psi Vortech S-Trim Supercharger (12psi on the way)
Eibachs, Tokicos, 96 Brakes, SFCs, STBs
PP Y-Pipe, Custom Stainless Cat-back, Bullets
http://members.home.com/fhurderjr/sho.htm
Mocha 91 SHO
"Monique"
White 95 SHO MTX
"Jezebel"
Mocha 91 SHO
"Monique"
