91 sho fuel pump issues
91shostopper
~SHOstopper~
waukesha
im having issues with my fuel pump and im not sure if its wiring or the pump. any insight and ideas to try are greatly excepted. also having issues with camshaft position sensor. again any insight is greatly appreciated.
Phoenix
SHOHOLIC
QC , Canada
Pull the codes first so we can point you in the right direction.
When the pump stops , in general its either the pump or the CCRM module which provides power to the pump. Wiring issues are pretty rare in these cars.
For the CID , its either the sensor is bad , replace it ,or sometimes the cam seal behind it is bad and its leaking into the sensor.
All the parts are available.
it would also help a great deal if you told us what the issues are that you are having...
SHObogdan1
Michigan
So 91shostopper...did you ever figure out what issues you have with the fuel pump and/or cam position sensor?
poffffd
