I recently (a month ago) replaced the VC gaskets. After which, I forgot to completely tighten the EGR vavle where it mounts to the intake plenum. I ran the car, which drove poorly BTW, and quickly discovered my mistake... but not before loosing one of the EGR bolts. So, after removing the other bolt to find a replacement, I reinstalled the EGR valve onto the intake... minus the gasked which disappeared into the bowels of the engine bay. It was replaced a day later. Also during the intake reinstallation, I broke one of the vacuum hose that leads to the back of the plenum. I repaired it that day.
Recently, the car began loosing power. It felt like I was driving uphill, at 5,000 feet, in 99% humidity on a 110 degree day. Secondaries open, but serious lack of power. I also get intermittent CEL's at highway speed... particularly after accellertaing onto the highway. The CEL stays on for a few minutes and then goes out until I put my foot back into it.
Ran the KOEO and KOER tests:
KOEO
52 - Power Steering Pressure Switch/circuit open - PSP (Again, probably didn't turn the steering wheel again.)
Meomory Codes
33 - EGR did not open/ respond during test or if memory code, did not open intermittently - EVP EVR PFE
34 - EGR did not respond properly during test - EVP
EVP sensor is/was high - EVR
PFE sensor is/was out of range - PFE
35 - Engine RPM's too low to test EGR system - EVP
EVP sensor signal is/was high - EVR
PFE sensor signal is/was high - PFE
I then ran the KOER test:
12 - Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low) - ISC
I haven't checked the nostrils for desbris yet (will be doing so in about an hour.) I do not remember cleaning them when I had the intake out of the car for the VC gasket installation. My guess is that they're pretty balled up since Im getting EGR codes and an IAC code. Just wondering if it might be something else like the EVS or the EVPS?
Thoughts?
KOEO
Meomory Codes
Thoughts?
