idc1233333
I just purchased a 1989 SHO for $450 because it has a shifting problem. I absolutely love SHOs (my daily driver is a 1998 V8 SHO
). I have been told by a few people it sounds like I need a new clutch. They say maybe the throwout bearing isn't releasing the pressure plate. Whats happening is you cannot shift into gear normally. When the car is off you can run through the gears fine. However to drive you have to put the car in first then to shift pass 25 mph. Staying above 25mph you must put the clutch to the floor tap the gas and it will slide out of gear. To engage second you must rev it between 2,100 rpms and 2,500 rpms and it will slide in. You must do this all through the gears 35 for 3rd 45 for 4th 55 for 5th. It has 165,000 miles on the body and 80,000 miles on the engine. I heard that maybe there are two different sized clutches from gen 1 to gen 2. I don't know if this one has been changed if thats true. Any help would be appreciated. If it is the clutch how does the clutch come out or does the whole engine need to drop. Im not a mechanic but Im slowly trying to teach myself and forums like this help so much. :thankyou: I already removed the entire interior, it was taken over by mice. I live in RI and I think the only shop close to me is nesho (who are great guys). Once again any input is appreciated :wave:
