Dual battery setup is officially complete, and the first start immediately stood out. Cold start came up, then smoothly tapered down to idle with no mini oscillating at all. Once it reached warm idle it stayed steady and composed. I gave it a couple quick throttle blips and it settled instantly and clean, like nothing was even asked of it. That alone told me the foundation is finally where it needs to be.
The system uses a Braille B3121 up front paired with an Odyssey Extreme PC925 in the trunk, tied together with full 1/0 cable. The Braille weighs about 21 lb and handles cranking duty up front, while the PC925 comes in at 25.9 lb in the rear and adds real reserve capacity and buffering. Total system weight is right around 47 lb, but the bigger win is how it’s distributed. Instead of one battery concentrated in a single spot, the weight is split front and rear, which is simply better for balance, stability, and how the car behaves under load, acceleration, and braking.
From an electrical standpoint, the car feels noticeably calmer and more stable. Voltage no longer feels like it’s being stretched thin during transient events. With how far this car is from stock, a single lightweight battery was always living on the edge. This setup finally gives the system the headroom it needs to operate confidently instead of reactively.
I haven’t started tuning on this configuration yet, but I fully expect the benefits to carry into tuning consistency. Stable voltage means cleaner sensor data, more repeatable injector behavior, and fewer corrections during transitions. That doesn’t create power on its own — it creates control, and that’s where real progress comes from.
If these cars “eat batteries,” this one finally feels fed
Used the ZBAD1 magnet mounts. Covered in DEI protective loom. I started on finishing my Rife sensor wire install to the ProLink+ but got stuck inside the interior for a 5V power source. I didn’t want to load up on the TP wire. I found a 5 V regulator from Aeroforce. On the way!
