802SHO 2010 Build
Cincinnati,OH
It would be nice if we could work together. Some things are achievable by not shutting others out.
The things I’ve done on other platforms have changed how things have been done.
Personally as far as ECU control unless the ECU is swapped to a Tricore or a standalone it’s going to be held back.
Sooner we all recognize that we can work together on making that happen. It just so happens I have a way to do it from doing it on other platforms.
Majestic
Right on! You guys keep supporting the one who attacks a reputable tuner who actually makes parts and tunes for this platform. I don't know either one of them and I was supportive of Andrew's build until he went off the deep end with the unprovoked attacks on GH. Nearly every post Andrew makes takes a shot at GH for zero reason.
Whatever. I'll just read here from now on, if that. Nobody has broken 11 on this platform and likely never will as long as there is constant BS when none is needed. Dude got his feelings hurt when told that his stripper couldn't be tuned with the old ECU and then went full *******.
Later.
Cincinnati,OH
Later.
And the thing I just want to put out there if it could be done it wouldve been done. Nobody ever tried to step on anyone’s toes and say, “this cannot be done”. Without A reason why.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Update: Major Progress
I started by replacing the starter and alternator. Both were original Motorcraft units with 16 years on them, and at this point reliability mattered more than trying to squeeze a little more life out of aging components. While I was in there, I permanently removed a couple of harness branches that were no longer serving any purpose, specifically the A/C motor and secondary O2 harnesses that were tied into the alternator wiring. With those systems long deleted, cleaning that up made the engine bay simpler and eliminated unnecessary dead wiring. The alternator install itself was straightforward, but my custom belt setup with the A/C deleted meant I had to order a new Gates belt and wait a few days rather than fighting the old belt off and back on. IMG 7325IMG 7330IMG 7374IMG 7376IMG 27197C45 6E1F 4024 B27E 207FE77C5E0DIMG 7416Once everything was bolted up, I didn’t immediately test the alternator or starter on their own. I finished the mechanical work and moved straight toward validating the electrical system as a whole.
Before starting the Rife 300 psi EMP sensor install, I went back to the real problem that had been looming over the car: TCM power loss. I’m not going to lie, diagnosing the BJB and TCM power path is intimidating. It’s one of those areas where guessing or moving too fast can create more problems than it solves. Buying the spare BJB turned out to be the single best decision I could have made here, because it let me slow everything down and fully understand the circuit without touching the car. I could dissect it, trace it, and make mistakes on the bench instead of on the vehicle.
I really started digging into that spare BJB. With it opened up, I was able to clearly trace Fuse 49’s load side out of the BJB and into the harness. That wire is green with a white stripe. While doing that, I identified a second green/white wire leaving the BJB, which belongs to the load side of Relay 52. Relay 52 supplies ignition-switched power to systems required for the car to start and run, which meant I now knew there were two nearly identical green/white circuits serving very different purposes.IMG 0912F99C 5D40 4B3A 9242 D951E46D7198IMG 7453IMG 7454
Using the spare BJB, I dissected it in the exact way I planned to open the harness on the car. Same loom location, same wire exposure, same approach. That allowed me to positively identify both green/white circuits without guessing or risking the live harness. One circuit feeds Fuse 49 and ultimately the TCM, the other feeds Relay 52 and has to remain intact for the car to start.IMG 488AEF94 EE14 4D7D A455 84640C661DE8
IMG 7582
On the car and in the engine bay the wires had way more tension so I removed the loom back to the BJB to find them and expose them. Found them. From here I paused and did something less intimidating.
I installed the Rife 300 psi EMP sensor. The mechanical install is complete and mounted cleanly using Zbad1 magnetic mounts. I’m waiting on proper 26 AWG wire to finish extending the sensor leads into the HP Tuners ProLink+, since stepping those tiny signal wires up to 18 gauge didn’t make sense for a pressure transducer. Once that wire arrives, the EMP side will be finished properly.IMG 93DFC828 E453 4CE6 9926 D0D40A06AACDIMG 21E6F40D 7BBC 4281 80C6 D0E8E348BFA2IMG FFA42FF5 6593 44F1 BC30 154343E269DFIMG 7599IMG 7608IMG 7611
I added extensions to each wire so I’d have room to work cleanly around the battery and switch panel, and for the first time broke out the soldering iron. Practice first, then committed. Clean joints, heat shrink, no shortcuts.IMG 7645
At that point all the wires were already cut because I had added extensions, so I labeled everything clearly as load and feed on both circuits. I didn’t want to power the feed side of Fuse 49 and backfeed into the BJB, which would have been pointless. For testing, I reconnected one circuit at a time by twisting its feed and load together while leaving the other circuit completely disconnected. The first attempt resulted in a no-start, which immediately confirmed that Relay 52 was still disconnected. From there it was simple: I reconnected the Relay 52 wires, then disconnected the Fuse 49 feed and load. I powered the Fuse 49 load directly from my switch panel and left the feed side isolated.
When I got it right and turned the key, the car fired instantly. Crisp start, no hesitation, no drama. The new starter and alternator made everything feel solid, and most importantly the transmission solenoid buzzing was completely gone. The car sounded healthy and boring, which is exactly what I wanted at this stage.IMG 7650 After shutdown, I let the scavenger pump run for about 30 seconds, and the TCM stayed awake, forcing the instrument cluster to remain active and showing ABS and traction control warnings. That tells me the module is fully powered and stable. At this point the TCM is effectively race-spec: manually powered, isolated from the compromised BJB, and fully under my control.IMG 7651
This was one of those repairs that wasn’t hard, but demanded patience, verification, and a willingness to slow down and think. No guessing, no vibes, no assumptions. The spare BJB made all the difference, and bypassing the compromised circuit entirely was the correct solution. The car is finally back on solid ground, electrically and mechanically, and now it’s ready for a test drive when the weather improves. Until then I’m moving on to the rear trunk battery install and can’t wait for my Maxx Velocity TurboGuards to arrive. They sent me a pic of them coated in Illusion Purple. 5193755F EE1F 4BEF 99B1 CA78D3EE45DF
802SHO
Quick validation update. I had the SHO outside while I was replacing an ABS speed sensor on my Raptor, and once that was finished I used the opportunity to run a validation test. I let the car idle for roughly 15–20 minutes to fully heat-soak it, placing it squarely in the same thermal failure window where the transmission issue had consistently shown itself before.
IMG 7688IMG 7690IMG 7686IMG 7685
After that, I performed several reverse tests backing up into my garage on an incline. This scenario applies enough load that, in the past, the transmission would drop in and out when TCM power was compromised. When I had previously jumped power to fuse 49, it would stay “alive,” but engagement felt fast in-and-out, a brief hesitation caused by partially energized solenoids losing power under load.
This time there was none of that behavior. Reverse engagement was immediate and consistent every time. No solenoid buzzing, no hesitation, no brownout. I even applied enough throttle to briefly spin the tires, something that would have instantly exposed a weak TCM power state before. Everything remained solid.
This was a small test, but it was a meaningful one because it targets a known, repeatable failure path. It passed with flying colors. At this point I’m comfortable moving forward and buttoning things up, and I’m likely going to move the TCM power to its own dedicated switch for cleaner, more intentional control.
I then started on the rear trunk battery install. I’m going to ground it to the rear subframe and run the positive up into this grommet and tight to the undercarriage to the engine bay, to the front battery. IMG 7668IMG 7669IMG 7671
Zinprogress
That solder job looks like a legit fire hazard. Would hate to see $100k build burn up over some poor solder. Check this video out, it might save you some heartbreak.
That solder job will be fine but does look god awful. Either no flux or not enough heat or a combination of the two
802SHO
Andrew looks good, I'm thinking a cover over the battery to gaurd from sparks if any were to occur. Not a good place to have a spark.
Appreciate the concern Frank, safety is always priority one.
Just to clarify a few details on the setup: The battery terminals are facing away from the fuel cell. All 1/0 power cables are hydraulically crimped, not soldered, and fully heat-shrunk. The battery is mounted in a rigid aluminum cradle that physically cannot move. The fuel cell is an aluminum cell, not plastic. A Class-T 300A fuse is mounted 7.5” from the battery, which protects the entire length of the positive cable in the event of a short
I do get where you’re coming from though, and I appreciate the safety-first mindset
802SHO
For context, I understand exactly what flux does. It cleans oxidation, improves wetting, and helps solder flow, it doesn’t magically make a joint stronger or more “correct.”
I skipped it intentionally while learning the process. The joint may look crude, but it’s electrically sound and mechanically solid.
lol kind of extreme criticism for a beginner solder joint but I appreciate the criticism.
Zinprogress
Apologies, it wasn’t meant to be a direct attack. As I said it will be fine, but the most important part of using the flux is that it helps the flow of solder. Once you get used to it, it almost IS magic how uniform it sets in.
Brumfield780
