Engine fits!!! Bc…..going top mount with a hood exit exhaust! Instead of “trying to make room” I’m going to utilize the real estate that’s already there by relocating the battery and intake. Approved by my engine builder and he recommends about 3ft of exhaust to not accidentally suck in fresh air and throw off the o2 sensors.
Matching the G25 turbine inlet vbands with 2.25” stainless and 3” stainless turbo downpipe/exhaust. Let the fun begin! I’ll be able to do anything turbo and wise at my finger tips. They’ll actually get cooling from my Race Louvers hood vents. The PTU will get less heat. Each turbo will get a PTP turbo blanket so the rear turbo won’t cook my brake master cylinder and the front turbo won’t add unnecessary heat to the top of the trans.
It’s going to look sweet to pop the hood that’s for sure. I’ve been debating to go top mount for about a week, had to just shake off the fear of the unknown. Would adding 1.5 to 2ft of piping to my manifolds ruin my build? Would it have too much lag? Would it fall on its face? I don’t think so. Turbos will definitely breathe with very little exhaust. 2.25” piping will be easy to run them over to where I’ll have plenty of room. It’ll be a smooth transition too and retain some velocity. Keeping it as compact as possible as recommended by
@Bluezone.
I could go with a power steering rack, but not know it’s dimensions until “after” buying it….potentially it still doesn’t work…potentially it does and then I think maybe I can chop up my tear turbo downpipe …..but maybe I chop it up and for whatever reason it just doesn’t work….then I’m out for the price of the rack plus I just turned a sellable set of downpipes into scrap metal. Want to keep it as simple as possible. Adding piping to the manifolds and just moving them to a better spot doesn’t get any more simple than that.
Now the real fun begins and I actually know what I need to do…..haven’t felt that way in a few weeks. So I’m excited.
Will it be optimal… don’t think so….but is it better than OEM location and hybrid turbos? I think so. Maybe we can speculate that if it was more optimal of a setup it would have ran 9.99 instead of 10.3! LOL! I see a stand alone engine management system in my future.
Side note: picked up more Race Louvers from
@aaron240 to put a set in the rear bumper. And got new hardware for all, not doing rivets I’m doing nuts and bolts, black bolts. I want to easily take them off for whatever reason (vinyl car wrap)?
