802SHO 2010 Build
SeanDev
First look at the modified OEM 13+ ported/thermal coated exhaust manifolds with G25-550 turbine inlet vbands welded. View attachment 83612View attachment 83613View attachment 83614View attachment 83615View attachment 83616View attachment 83617
First look at the G25-550’s mocked up. View attachment 83621View attachment 83622
This is going to take some finesse….stay tuned!
I know you mentioned your builder, I believe Max Power in Illinois is doing the work. Is that correct? I'm looking to go and have a built engine and drive this car to 200,000 and beyond. 550whp 500-550wtq is my goal. I would make it my own project, but unfortunately health and other things going on I just don't have time to do the engine build myself
Side note, I need those damn raybestos plates.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
I understand and I hope health wise everything is going to be ok? Yes Max Power Automotive now located in Crestwood, Illinois. 630-699-5631. Matt Pohnan is the owner.
802SHO
Some interior updates and progress. Aside from adding back my front door cards, I was able to get my Schwartz Engineered Performance new seat brackets and Kirky seat with Sparco sliders installed. Before I was stationary and once bolted it was where it was….now I can slide it back. So nice! FED04DF2 2658 4213 97B6 F55F714A2430C6974BA5 5F46 48B5 8682 4DE2B64AA366AA5FCF5D 6312 4A0A 9FB8 6F8A1B430EE9
I also will be removing my nitrous controls from the 3m tape attached to the side of the shift column to these steering buttons8AE58B9A 375B 4498 A9C1 C044C06C9D140EC5E001 729D 47D2 A680 16AFB0AC2621
I’ve always wanted one of those 3 gauge pods to replace the main Sony Dash speaker bc I absolutely love that look. But I ended up buying this tablet setup with brackets a fellow SHO owner listed for sale in one of the EcoBoost SHO FaceBook groups, a little over a year ago. It attaches very slick to the inside of the center Sony dash speaker and it’s going to be my Torque Pro gauge display of 6 digital gauges running directly off the OBD2 port.52964FB7 7E91 446F 82CB 5BEDB3ECF002
CF3BBFDB 51F7 4DBD 9CD7 3E134E398A0129315C0F 6BB5 41D9 B953 9A8FA8B813804C7070F0 842D 4964 929D E2BDEE7E1304
Once it’s up and running, I’ll need to hide the wire in the dash and get a black cord (came with white) so it blends in better. It’s going to look like this all said and done and what I think is a really cool alternative to the current 3 gauge pod available. Picture below on what sold me.
4C8BBE74 FA3F 4FB7 B348 0ACB5DE59331
SeanDev
Spoke to him today. He seemed against raybestos. Says they having backing issues in their plates which separate. Unfortunately not much can be done to transmission. He is 8 to 11 months out just getting my car in. Estimate is $12,000 to $14,000 for build, is that by chance close to what your estimate is?
802SHO
I paid the lower end of that. Prices are going up everywhere though
802SHO
Test Fit #2. Closer but steering rack not cooperating. Next thing to try is adding pie cuts to the rear manifold, to bring the rear turbo down, in, and angled slightly back up at an angle. 0F740383 E7FA 452B 8E5F 0DC8E3038D9C267CB61A C803 44DD A6B9 E05530B156450E4C3E97 A730 4263 B154 809E18B8B13D34F71996 C66E 4CA2 A8E3 B1996D9E8AF9653BDB6C 1285 4B6E 8522 1521E202CFA6
FrankK
Colorado Springs, Co
Can you remove the TC and see what the space looks like after you drop the engine down to where it needs to be? It might give you a better idea of what you need to do.
802SHO
Any chance that the transmission is drooping slightly?
It’s actually supported bc without axles in and connected to control arms/suspension it has nearly no bracing and with weight of PTU needed extra bracing under. So it’s good
313tiger
