700 whp SHO!
yamahaSHO
E85 whore
Arkansas
Almost... The clutch wouldn't hold on @zach44102 's car anymore, but once it is replaced, it will be over the 700whp mark. I am pretty sure this is the highest dyno I've seen on a SHO; definitely on the Yamaha motor. Prior to it slipping, we had it up to 560wtq and his turbo will hold that to redline.
- Stock block
- Stock crank
- Stock rods
- 13:1 compression Weisco pistons
- Stage 2 cams
- Valve springs
- Head studs
-67mm Borg Warner S400
-E85
You can find out more on the car: https://www.facebook.com/Blueturdtaurus
outstanding!
I also noted that Zach is using the glowing turbo as his right hand headlight...
I'm curious what boost level is delivering that power.
yamahaSHO
E85 whore
Arkansas
So, the car was actually running 27 PSI last night when we started using the higher maps.
1st pass: Let out as he saw the hood pop - 11.5
2nd pass @ 13 PSI:
43199950970 fd9bb050fa b
3rd pass @ a slow ramping 27 PSI:
4th pass @ faster ramping 27 PSI (but experienced some sort of boost drop and raise - looking into it as I intentionally turned off boost feedback - I will probably run 35 PSI on this motor if it keeps kicking)
44951972382 29e9060b45 b
I believe we'll see another 1320 Video feature on this car soon... :)
This should make for a good photo... I stole the video off of Kyle until they get some posted.
So the car will definitely go 9's on this motor. I can't imagine once we swap over to the aluminum rod and O-ring'd motor. And hopefully, we will have more press on the car in the very near future... Will share when we know more.
