6x9's
SLOSHO89
San Luis Obispo, CA
Has any one put 6x9's into there Gen 1 SHO's? Is it possible while still keeping the original grills/covers?
Oxford White '89 SHO
Slicers, SHO+ hood and spoiler, Met.-Red and Gold Intake.
Web Page www.geocities.com/web_page66/
edogg23
Buckley, WA
I have them and no they will not fit with the original grills and covers. If you want to keep the original grills and covers buy 5X7's. They fit perfectly.
_______________________
Erik from Orlando 89 silver SHO 128k miles dynomax cat back w/out resonator, ss y-pipe, ss underdrive pulleys,eibach springs, koni struts, pp motor mounts, 17X8 fitipaldi polaris rims with 245/45/17 zr comp t/a tires SHO FEAR written across the windshield, v1 radar detector quantum tinted windows, custom cold air intake with a ractive heat shield. 14.8 @ 93 mph in 90 degree weather!
Wildstar
Fort Worth, TX, USA
6X9s will fit underneath the package tray. You can see how when you look under there. Crutchfield had the little brackets to make it easy, but you don't have to have them. I left my covers on the inside and removed the speakers. The 6X9s sound much better, IMHO
SLOSHO89
San Luis Obispo, CA
Do you happen to know what the part # for the brackets is? Or a better description?
Efren
Wildstar
Fort Worth, TX, USA
Don't remember the part number, they sent them with the speakers. If you look on the bottom of the package tray you will see the cut outs for the 6X9s. The JBL systems used 6X9s underneath the "high-mounted" 5X7s as sub-woofers(Gen I). You will also notice 4 little "squares" cut into the sheet metal that look like something is supposed to slide in there. Something is. It's the bolts to hold the speakers in. The bolts simply had big(though thin) square heads on them. The heads slide in the "squares" and the speakers slide over them. Tighten up the nuts and there you go. I would think any stereo installation shop would have them. Or something close enough.
