$50 to the one that solves this.
doclees
Harrisburg pa
I had the same problem...Turn out to be the Daytime driving lights plug located in the drivers side fender well....It is capped for use in America....The cap filled with water....
Got a wiring diagram that would explain that one?
doclees
Harrisburg pa
Ok so far it looks like Shovert will be getting the $50. We had a glitch in the glitch with a cheap key switch that stuck to the on position frying everything again. Give me a few days to prove this fix a fix. On the issue of hard start like dieing battery and bucking. Codes pulled gives me a 19 so Cam position sensor. Only have about 30k on this one so didn't think it was that. I found an older post with Area91 commenting on the buck and hard start being the CDI. It will be changed tonight. About 50k on the cam seal and still dry as a bone.
Shovert
ky
If that happens. Donate to forum. I am here to learn, listen and help rarely if can. Don't assume new or recent new parts are good. Test Test. I do refrigeration work. I replace of new or fairly new parts all the time. Face it quality of parts are not what the should be. Maurice
Shovert
ky
Someone has too high opion of me. Just glad to help. Maurice
poffffd
