400ft-lbs of torque?
Status
Not open for further replies.
strings1732
RMTE-TRBO-SHO
colorado
doug what size intake piping are you using for this? Both exhaust and charge if you could let me know please. I like how you ran the intake tubing and might be making some changes to mine because of that. I will soon be upgrading to the .63 turbo as I run out of steam at around 6200-6500 still with my .60 housing. I did realize that intake temps were still very high without an intercooler and found out that the water injection i was using wasnt enough. even though the pipes felt ice cold, the intake temps were ******* my gauge at around 250 IIRC. with the intercooler on a 100 degree day, I havent seen them over 150.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Charge piping starts at 2", then transitions to 3" by the time it comes out of the air cleaner lid.
The exhaust piping is 2 1/4" in and 2 1/2" out and all Jet Hot coated.
This car is also out of turbo early. It's got ewnough motor to make more power up top. It's got a .63 AR housing on it now , but it could use the next size up housing which is a .84 AR. It's $250 that I really don't want to spend.
With a slot type MAF, the charge air temp is incorporated in the MAF. I didn't monitor the temps, but I did change the programming to account for the higher temps.
That kit looks great, I really like it Doug.
Whats the cost compared to your S/C kits?
-Sam
Thank you, Sir. The turbo setup will be about the same as the supercharger kits. A turbo is half the cost of the supercharger, but the piping is much more expensive. The oiling system will be different than what I have done here. There's over $1000 in oiling system in this car.
The next kit will be for ATX cars and even Gen III cars.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Right away, actually.
Give us a call. We can talk about pricing and kit types.
Joe_SHO
ND
Looks like the stock fuel pressure regulator though?
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Sure does.
60lb injectors, high volume pump in the tank and the stock regulator.
AREA 91
PA SHO SHOP
Area 91
I just can't see myself putting a turbo under my car. I wouldn't want to come out the store and have a missing turbo! :nut:
You wouldn't look suspicous to a police officer, or anyone else for that matter when you're on your back trying to fix a muffler in broad daylight on an old car! :munch:
Move to my neighbor hood. Most leave the keys in the ignition while parked in the drive way.
chrism3784
West Palm Beach, Florida
Original questions states who thinks this will put out more then 400 lbs at the wheels. I don't! Maybe the motor alone. Unless it of course has the better diff that doesn't have the pin problem. If this has the ungraded diff I'll believe it, if not, it would blow the diff before even reaching the wheels.
yamahaSHO
E85 whore
Arkansas
Seriously d00d?
Sure does.
Planning on running E85 with those injectors? What injectors do you have in there?
SeanMc
NoMoSHO
I only said "thanks" for the fail.
Nice work Doug!
gmail
Well-Known Member
sunbury pa
Seriously d00d?
Nice work Doug!
see there we go people... instead of just explaining to the guy you have to be smart and pick on people, you know its more productive when you calmly explain to someone and not treat them like a retard
is it the growing up as a rich kid in you that made you act like a dick to people or is it something you tried being good at over the years?
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
I had 48lb Accell injectors and it was dead out of fuel at 5000rpm. So we put the 60's in and now there's no problem with fuel, even if we decide to go to the bigger housing and 20psi or more.
Not enough fuel is a very bad thing.
AFR is steady at 12:1 until it chokes on the housing where it creeps up a bit.
gmail
Well-Known Member
sunbury pa
sorry to mess up your thread with this garbage doug....
i must say you did some nice work with everything, i just cant believe you did the work and didnt make him take off the trailer hitch and wing ;)
yamahaSHO
E85 whore
Arkansas
Why the fnck did you quote me in this post?
How much boost are you running again? Which exact injectors are you running?
SHO U UP
SHO Guru
Virginia Beach, VA
That's THE car I was talking about back when I picked up mine. Those are some older pics as my car is on the lift next to it for one of the pics. The car does sound sweet and looks stock. I wanted to go for a ride in that ***** while I was there. And don't let Doug fool you guys, he had his hand on that wing too! (He had to fix the way the owner mounted it) :laugh_ti: Sick numbers Doug!
Sho Amo
SmkTyresntDrugs
Olney, Md
Doug, i think i have the exact same turbo. Where can i get the bigger exhaust housing?
Status
