400 hp pull.
SHO M0nk3y
Edmonchuck, Ab, Ca
submitted by 217962
super high output. I have one myself. not 400 hp tho lol. Thats some good numbers. a guy on the sho forums has a 500 + hp 91 sho. It walks everything.
What the.....Is this true? Anyone?
Brett
SHOs before HOs
Minnesnowta
Geez, ive never seen something resposted on the same site 3 times in a day! :oogle: Saw the first post made by the Owner of this car (NCtaurusSHO) and then another in the same section of the forum, and then another on SHO related section of the forum, search for new posts, dont know how you could've missed it :thumb:
NCTaurusSHO
Guest
Elizabeth City, NC
we are making history aren't we!!!! haha. I don't know about 500 on the forum though. i don't recall a 500+ dyno. maybe 430hp....
Shoaz
Studly dood
Scottsdale, AZ
I have a vid of Pat's car pulling 445hp at the wheels, which is over 500hp at the crank assuming modest drivetrain losses. There've been several 500+hp forced-induction SHOs, and IIRC Josh had a pull over 600hp.
Force4
Guest
Wisconsin
im talking about ELTORO. His numbers are way up from 460 he just wont tell anyone. I made that comment by the way.
SLoW_SHO_316
Runcarsnotwords
Connecticut
You're nuts, he's definately not making more then 430whp. You can even ask him!
40BelowSummer
Puerto Rico
blue92 said:
There's a guy in Texas with a supercharged SHO runnin 21 to 23lbs of boost and getting close to 600hp to the wheels. Supercharged is the way to go. This guy in Texas owns a speed shop called North Texas Performance. :biggrin:
Shoaz
Studly dood
Scottsdale, AZ
I did a little poking around (not much) and found, without much effort, several SHOs making 500+chp.
Here's one, with stock internals other than cams, from quite a while ago:
http://www.shoclub.com/membersonly/joshturbosho.htm
Both of Pat's s/c cars are over 500chp, his track car making quite close to 500whp, which would be ~585chp assuming 17% loss.
Ransom's car with low-comp pistons is well over 500chp. The dyno plot is apparently archived here.
Edit: Found the plot in his post:
Other examples aren't hard to find. Note that Josh's dyno run is almost four years old (Ransom's is almost five years ago), and these guys haven't been sitting on their hands. The vid I have of Pat's white car is from no later than 12/03.
Congrats on the good success with the turbo, I think it's fantastic. Clearly there's opportunity for more, though. ;)
40BelowSummer
Puerto Rico
yamahaSHO said:
Nope, Pat has been running a completely stock long block (from the throttle body to the exhaust manifolds) on his white '91 making 445whp. The only time he has had any problems is when his water injection quit working. By personally seeing how well his car has responded to WI, I went the same route.
His '89 SHO (race car) is the one with the forged 3.2 pistons running 17lbs of boost with no charge cooling at the moment. This setup has yeilded 520whp and now he is adding a 2-stage water injection kit and most likely, more boost.
FordLover
Houston, Tx
NCTaurusSHO said:
maybe 430hp....
I think this is the funniest thing in the world...Tony should have a patent on 430...it's like his magic number. I personally think it's a lot more like 330 hp...he just wishes he could dyno over 400.:rofl:
Toolman
Boost it!
Grand Lake, Oklahoma, USA
antbrdwar said:
Are you surrendering already? The turbo beast will not succumb to a blower! :p That will be a hella good matchup..
It's okay, Tony likes to have his SC'd ego stroked (along with other things!)
