3rd gear synchro shot?
Sh03d
Sho Ed
Fairfax VA
At any speed 35 and over I cannot downshift into 3rd without horrible grinding. I have to shift into 2nd then back into third if I want to down shift without any grinding. Is this the 3rd gear synchronizer? Would a new set of blocking rings fix that or will I need a whole new synchronizer?
jessemachone
No Mo SHO
Scottsdale, AZ
3rd gear
Mine does that too! I thought I had the rare 3rd gear indicator system installed. J/K i have a Bizzy tranny to install to remedy the problem. :thumb:
TYSHO
Earth
Most likely just a blocking ring, but if you continue to grind the gear, which I believe you are avoiding, the synchronizer will get toasted.
